Discussion topic: Wi-Fi not working
This message was authored by: Chiropodist1970
Wi-Fi not working
My Wi-Fi will not get past the orange stage on the router
Re: Wi-Fi not working
@Chiropodist1970
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
▪️I AM NOT A SKY EMPLOYEE ▪️
