Discussion topic: I need an engineer but when calling it doesn’t help
This message was authored by: Tarap03
I need an engineer to come to my home I've recently gotten internet the hub wont work I need someone to look at it as I've I look after a child that has special needs and have a child of my own I need it working as it's my only way of getting contact with anyone in cases of an emergency and I'm not happy that I'm paying for something that isn't working i also payed for an engineer to come out through sky and there still not out or Made contact about coming out
Re: I need an engineer but when calling it doesn’t help
@Tarap03  An engineer won't be sent unless there is a line fault.  And one certainly couldn't be sent on the back of a post from an unlinked account.
What issues are you having with the hub, in what way isn't it working?
@Tarap03
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
Who did you pay to come out? Apart from a potential appointment at a weekend you don't pay extra.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
