Discussion topic: Wi-Fi not working
Message posted on 27 Jun 2025 10:32 PM
Wi-Fi not working
Wi-Fi keeps dropping in and out all day and the speed has dropped dramatically in the last week
Message posted on 28 Jun 2025 04:25 AM
Re: Wi-Fi not working
@Brian1310
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
