Discussion topic: Wi-Fi not working
This message was authored by: Esme3
Wi-Fi not working
No wifi connection, Done a wifi test says everything is fine, restarted the router, unplugged and plugged it back in and still no wifi! Can find any help anywhere
Re: Wi-Fi not working
@Esme3
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
For a broadband issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
