Discussion topic: No internet connection
This message was authored by: DavidHurditch
As stated above. Checked wiring and resets.
Re: No internet connection
@DavidHurditch
For a broadband issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
