Discussion topic: Wi-Fi not working
Message posted on 29 Apr 2025 01:05 AM
Wi-Fi not working
we have run a test and it says everything should be working fine at the Wi-Fi is not working. Not quite sure what the issue might be. Look forward to hearing from somebody soon
Message posted on 29 Apr 2025 01:11 AM
Re: Wi-Fi not working
Our WiFi has also been down for an hour I don't know what is going on
Message posted on 29 Apr 2025 01:18 AM
Same issue. It's been "Connected without internet" But the sky app says everything is good. It's been over an hour now.
Message posted on 29 Apr 2025 01:24 AM
Yeh I don't know what's going on
@Paris9 wrote:we have run a test and it says everything should be working fine at the Wi-Fi is not working. Not quite sure what the issue might be. Look forward to hearing from somebody soon
Message posted on 29 Apr 2025 03:26 AM
At the time of night you've all posted it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back by 7am use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
