Discussion topic: Wi-Fi not working
Message posted on 20 Apr 2025 05:54 PM
Wi-Fi not working
My Wi-Fi is not working and I can not get it back on
Re: Wi-Fi not working
@SheenaL1
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
