Discussion topic: Wi-Fi not in every room
This message was authored by Doreen+cowe This message was authored by: Doreen+cowe
Had Wi-Fi throughout my home two days ago. Yesterday Wi-Fi not working in living room but working in bedroom where the router is.
This message was authored by Kevin-7248 This message was authored by: Kevin-7248
Re: Wi-Fi not in every room
Hi @Doreen+cowe have you moved your router or done anything from 2 days ago as you say until now?
If not, can you try turning the router off and back on and then conducting a speed test from where you couldn't get Wi-Fi in?
EDIT - I must also add, I know it is always personal preference, but having the router within a bedroom can be bad for when, if it is your main sleeping area, when sleeping within. The frequency over time could effect sleep / brain. Just for advice 😊 (Take or leave) 🙂
Sky Glass 65”
Sky Fibre Gigafast Plus
Been a sky customer through the ages from before HD boxes were a thing! When sky was a box you had to wind up to work 
