Discussion topic: Wi-Fi dropping
This message was authored by: MELRUK
Wi-Fi dropping
For the last few days the WiFi as been dropping a couple of times in the morning but today it's dropping every 15 minutes, done a check and everything seems ok. I've reset the hub and still having issues
Re: Wi-Fi dropping
@MELRUK
Not sure what check you did so if you haven't then try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
