6
This discussion topic has been answered Discussion topic: Wi-Fi dropping out
This message was authored by: Tommy+sand
Wi-Fi dropping out
The Wi-Fi drops out so if I'm listening to the radio in the kitchen it cuts out and Alexa says it's not conected .
The television picture goes bad and then loses connection so there isn't a picture so I turn everything off at the plug and it comes back .
Avatar for Tommy+sand
This message was authored by: Tommy+sand Answer
Re: Wi-Fi dropping out
It's white so it appears to be working
@Tommy+sand What do you see on the hub when it happens, see the link below!
@Tommy+sand If you have the full sky max package then you may just need a pod to enhance the wireless wi-fi signal around the property, but to get one you do need to call sky, details all about are below, so take a read!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
@Tommy+sand The only other thing to do is look at the WPA value you have set on the hub with your app, WPA3 or -T, may be it's default and WPA2-PSK may be better operation for your devices.
How do I check my WPA setting
@Tommy+sand The link below should explain how/what to do, will be wireless security settings.
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
