Discussion topic: Wi-Fi dropping out
Message posted on 05 May 2025 03:40 PM
Wi-Fi dropping out
Hi, my WiFi keeps dropping out. This is impacting working from home and being able to use the tv. The connection test says it's ok but it absolutely is not.
Message posted on 05 May 2025 03:48 PM
Re: Wi-Fi dropping out
@Isla9
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
