Discussion topic: hard to read, upper case, lower case, i or I, l or L
Message posted on 05 May 2025 02:43 PM
wifi fine on two devices can't get the older ipad to sign in. Tried loads of variants of the upper and lower case L and i, can't tell the difference. is the i, a lower case i, or an upper case i, is the I, a larger L with no tale, or what. It's crazy. Won't work. Please don't use these damn letters that are hard to tell the difference.
Message posted on 05 May 2025 02:47 PM
Re: hard to read, upper case, lower case, i or I, l or L
@VanessaIW Sorry not getting it, you have 2 devices connected fine, so the password is good, you can write it down on a piece of paper and make it as large as you wish.
Message posted on 05 May 2025 03:52 PM
found the problem, as the ipad is from 2014, I adjusted the hub security settings and it now works. Nice until i get a newer one.
