31 May 2022 07:05 PM
My Wi-Fi keeps dropping in and out across all my stuff iPhones iPads cameras etc. I have done all the usual resets and line checks but it still does it all the time. Any one any ideas do I need a new router and box ?
31 May 2022 07:18 PM
Posted by a Superuser, not a Sky employee. Find out more@Charliedogz Could you please post your router stats following the link below.
31 May 2022 07:28 PM
31 May 2022 07:37 PM
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 104518219 124383820 0 2915452 450609 686:54:33 LAN Up 133084493 149506749 2109002 137886820 142745426 686:56:03 WLAN (2.4 GHz) Up 25759612 50508258 1 20024 0 686:53:56 WLAN (5 GHz) Up 171627004 87471997 0 563480 0 686:53:52
31 May 2022 08:41 PM
Posted by a Superuser, not a Sky employee. Find out more@CharliedogzLooked at your router stats, the only thing that was a miss was a lot of collision packets on the LAN side with one on the 5 GHz Wi-Fi, all the uptimes are around the same. Does these drop-outs just happen at random places throughout the property or are you in the same room as the router when this happens?
01 Jun 2022 06:04 AM
01 Jun 2022 06:21 AM
Posted by a Superuser, not a Sky employee. Find out more@CharliedogzWhich kind of router did Sky supply you with from the link below? Could you also tell us if the router is hidden behind anything or in a cupboard out of the way?
Also do you have brpadband boost as part of your broadband subscription?
01 Jun 2022 06:00 PM
01 Jun 2022 06:06 PM
Posted by a Superuser, not a Sky employee. Find out more@CharliedogzIt might be worth trying to move it out from there if you can.
https://www.sky.com/help/articles/broadband-diagnostic-wifi-drops
Click on 2 best signal see if that helps.
02 Jun 2022 07:38 AM
Hi all
think I may have the same issue.
iphone/iPad not picking up WiFi in house from sky hub. I have another router connected via cable to the garage (work) and the WiFi from that is OK ( but won't reach all of house) so suggests a hub problem
several resets and off/on has not changed.any assistance would be welcomed to help calm down 2 tech hungry teenagers ! Thanks
