Discussion topic: Wi-Fi down
This message was authored by: Janine
Wi-Fi down
Wi-Fi isn't working. Ran a test and it says there is an issue. Then I pressed the fix issues and it came up with nothing. Middle button is flashing red then nothing on the hub
Re: Wi-Fi down
@Janine
