Discussion topic: Wi-Fi down yet again
Message posted on 26 Jan 2025 01:14 PM
Since going on to full fibre the WiFi goes down multiple times per week and sky diagnostics says all is good......
Message posted on 26 Jan 2025 01:19 PM
Re: Wi-Fi down yet again
@Rushfop
The lines may be busier due to the damage and disruption caused by Storm Éowyn which will also impact an Openreach visit.
