Discussion topic: Signal drop out
This message was authored by: Simonef92
Signal drop out
Since yesterday my signal keeps dropping out, enough that the TV goes off saying no internet. IV ran connection tests which say my connection is fine.. clearly not
Re: Signal drop out
@Simonef92
The lines may be busier due to the damage and disruption caused by Storm Éowyn which will also impact an Openreach visit.
