Discussion topic: Wi-Fi controlled socket outlets
This message was authored by: Paul77garr
Message posted on 12 Feb 2026 02:45 PM
does the sky wi-fi hub have both 2.4GHz & 5GHz outputs?
Find out more
Message posted on 12 Feb 2026 03:37 PM
Re: Wi-Fi controlled socket outlets
@Paul77garr yes all Sky hubs support dual band WiFi. On the black hubs you can split the bands if your I OT lkit needs that see Split Sky WiFi bands
Onnthe white hubs you can't split the bands so if the socketsceont connect go into the hub's Advanced Settings in the My Sky app temporarily turn off tge 5GHz band connect the units then turn it bavk on again.
