Discussion topic: Wi-Fi connection cannot be established
Message posted on 06 Aug 2025 01:33 AM
I cannot get a WiFi connection. I have ran all diagnostics, turned the devices off and unplugged them, left them disconnected for 5 minutes then plugged them back in and switched them all on. Still no connection. Diagnostic said looks all good, still no connection. Can't connect my phone to WiFi. None of my WiFi devices are connecting to WiFi. Please advise, thanks.
Message posted on 06 Aug 2025 02:21 AM
Re: Wi-Fi connection cannot be established
I've had to book an engineer to fix the problem from outside my property. You may need to do the same. You'll need to run the diagnostic from the Sky app. It's a step by step guide. If I managed then I'm sure you will too, good luck.
