This discussion topic has been answered Discussion topic: Wi-Fi calling drops the call.
Message posted on 04 Feb 2025 04:08 PM
I have no 4G mobile signal in my area so I use Wi-Fi calling all the time. When making a call if I'm moving around the house the call often drops out at the same place. I have a Sky max hub and 1 Sky max pod that gives me full Wi-Fi coverage. Does the Wi-Fi call drop out when the phone swaps between the hub and the pod? And if that's the cause then how can I prevent it happening?
Message posted on 04 Feb 2025 04:31 PM
Its likely to drop during the handover yes. There isnt a lot that can be done, many network solutions have access point roaming as a big focus when being designed, obviously Sky havent perfected this. Your solution would be to not move around unfortunately.
