Discussion topic: Wi-Fi Max - Dynamic DNS
This message was authored by Neil_knows_nowt This message was authored by: Neil_knows_nowt
I'm not currently a Sky customer but am looking to sign up for Wi-Fi Max .
My concern is that I need to set use Dynamic DNS to access my Home Assistant setup remotely. Currently I can do that with DYNDNS in my BT Router but can I do the same on the Wi-Fi Max router?
any help appreciated!
Re: Wi-Fi Max - Dynamic DNS
Hi @Neil_knows_nowt
Dynamic DNS is available on the Sky hub however it only offers the following providers;
- noip.com
- DynDNS.org
- dyns.cx
Also note the Dynamic DNS feature on the Sky hub can be flakey and is known to not accept complex passwords which may be a security concern for some so if Dynamic DNS is something you require at router level I would say you either need to consider a different ISP or use a 3rd party router with Sky.
I am NOT a Sky Employee
This message was authored by Krishnendu This message was authored by: Krishnendu
Can anyone specify where in the sky wifi max hub setting I specify dynamic dns.
@Krishnendu as far as I can see there is no facility for dynamic DNS on the white Sky hub 6 (model SR213)
