Discussion topic: Los light red on the ONT device
This message was authored by: Linton_A
Message posted on 14 May 2024 08:58 PM
The Los light is red even after I unplugged or switched off for 30 seconds as instructed. Besides calling in what can be done?
Find out more
Message posted on 15 May 2024 06:29 AM
Re: Los light red on the ONT device
@Linton_A You can use a mobile connection to run the connection test in the My Sky app to see if thst tells you there is a known fault affecting your line. If it doesnt give Sky a call as the ONT is not receiving any signal from the exchange.
