Discussion topic: Wi-Fi Issues
Message posted on 10 May 2025 10:07 AM
Wi-Fi Issues
my WiFi speeds are showing as good when checked via the Sky app & independent apps. However, in reality the service is really bad. My children can no longer access WiFi in their rooms. This was previously not an issue. I am having to use mobile data to send photos via Whats App in the house. This was also previously not an issue. The Sky Q drops out, also previously not an issue. No longer able to access WiFi in the Kitchen, bathroom, garden. I think that paints a pretty clear picture. Since I upgraded to Skys fastest broadband package, the use ability has declined significantly. I am not getting what I am paying for, which is now circa £140 per month. Not on Sky!!! I need a resolution as soon as possible!!! Wi-Fi is expected to be useable. I am at my wits end!!!
Message posted on 10 May 2025 11:00 AM
Re: Wi-Fi Issues
@CC76 You have got this all out now, so the serious part which none off what you posted helps. Have you upgraded to the FF service, you have taken the Sky Max (White) router and possibly have the subscription package... The original position off the old hub has it moved now to accomidate the new installation if that was so. The details are all needed, if you would like advice from the Forum.
If you do not then call to Sky for them to deal with it all.
Message posted on 12 May 2025 11:30 AM
Re: Wi-Fi Issues
OK, so upgraded to FF (white hub) fastest available, hub is in the same place as the previous router which was black. Never had any boosters but the WiFi was great all over the house & garden. No other changes.
Message posted on 12 May 2025 12:46 PM
Re: Wi-Fi Issues
@CC76 Cannot say how good or bad the Sky Max hub is as have never used, but if you do have the Max subscription then booster's are probably the only way for you to go. Information is all linked below.
getting sky max and how to get the pod's
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
Message posted on 14 May 2025 02:49 PM
Re: Wi-Fi Issues
Contacted Sky, got a booster sent out, seems to have improved the WiFi initially. We have to see over time if this works for us long term.
Message posted on 14 May 2025 04:12 PM
Re: Wi-Fi Issues
@CC76 That is all you can do, and if needed move it about to get the best and desired location for it.👍
Message posted on 19 Oct 2025 09:59 AM
Re: Wi-Fi Issues
I've just had the same problem for six months. Apparently after talking to Sky Tech you just have to turn the parent control system OFF (it's called the Shield) Then everything will work from then on. Well it worked for me yesterday, so I hope this works out for you When I spoke to the Technician he said that Sky knows about it but they wouldn't even put a note on the system to warn customers as a last resort you can turn the Shield off
