Discussion topic: Why does my internet keep going down
This message was authored by: Kez5
My internet keeps going down, this is effecting my sky a boxes aswel has iPads and phones
Re: Why does my internet keep going down
@Kez5
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
