Discussion topic: Broadband down
Message posted on 07 Oct 2025 08:28 PM
Broadband down
Can't get wi-Fi connection
Message posted on 07 Oct 2025 08:33 PM
Re: Broadband down
@Chrissy09
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
