Discussion topic: Whole road has full fiber but missed me out
Message posted on 20 Dec 2025 09:30 PM
Message posted on 20 Dec 2025 10:44 PM
Re: Whole road has full fiber but missed me out
@Elyouseewhy93 if you placed an order with Sky you can check its status in the My Order area in the My Sky app or website.
Message posted on 20 Dec 2025 11:01 PM
The fact that they've sprayed markings outside your house is encouraging.
The 10 houses that don't currently have fibre may be served from a different distributiion point (DP) and there isn't enough capacity on the DP for the other houses to connect you to that. E.g., in some cases one part of a street can be served by an overhead connection on a pole and another part served by underground cables.
In my case, once they surveyed they found an underground duct was blocked and so a hole had to be dug. It took several weeks from the Openreach survey before a man from the civil engineering dept. came to dig the hole.
