Discussion topic: When writing in microsoft word it continual stops and does not save.
This message was authored by: Jaki60
Since getting full fibre, I have struggled to use Microsoft Word without it freezing and not saving often.
Re: When writing in microsoft word it continual stops and does not save.
@Jaki60 if your issue is with one app the problem is likely to be with thecapp's set up on your device but check the auto save function of MS Word  is properly configured.
However if the device is losing connection which affects all connected activity the most likely cause is a poor network connection to the hub which is very common if you are using WiFi as improving connection speeds to the hub wont improve a dodgy WiFi connection in your home. Adding a WiFi extender can help see https://www.sky.com/help/articles/sky-wifi-max
However if all devices are losing connection then it could be an issue with your fibre broadband connection. The lights on your Sky hub will show that.
This message was authored by: Jon34
Is this word online? (web browser) or the Word Desktop app?
Avatar for Jaki60
Hi, it's word on line
