Discussion topic: When ever I test my broad band it says there is a Wifi problem
This message was authored by: KenV8
When ever I test my broad band says its good but there is a WiFi problem, press fix, which it then reports the WiFi is all good.  however when i long in again to test it imeeadiatly afterwards it says there is a WiFI problem to press fix ! stuck in this loop !
Re: When ever I test my broad band it says there is a Wifi problem
@KenV8 do you see anything wrong when using your devices? If you dont ignore the test if you do pist your hub's stats and some details somgorum members can advise seec Find your Sky Broadband router statistics
