Discussion topic: Whats the difference between connecting via wifiwofi extender and wired xonnection . Wifi wxtendee
This message was authored by: Wendy-woo13
Message posted on 19 Aug 2024 03:59 AM
When i check my broadband it says 4 connected tk black hub. Then i go to wifi. It says sine things connected to wifi good. Some wifi extenders and some wired connection. What does all that mean im thick sorry
Find out more
Message posted on 19 Aug 2024 07:54 AM
Re: Whats the difference between connecting via wifiwofi extender and wired xonnection . Wifi wxten
@Wendy-woo13 frankly unless you have an issue I wouldnt worry. The device listings on Sky hubs can be wrong especially if you have extenders or boosters. You cannot control what connects to what so it only becomes important if devices are not working properly.
