Discussion topic: What network is my router?...
This message was authored by: Martin295
Message posted on 03 Jan 2026 04:20 PM
Hello, is there anyway I can check if my router is on a 2.4ghz or 5ghz network?.
Message posted on 03 Jan 2026 04:33 PM - last edited: 03 Jan 2026 04:37 PM
Re: What network is my router?...
@Martin295 Which router do you have, link below and anything but the sky hub has both bands unless you have switched one off by yourself! If you need to check wifi analyzer software or direct connection to a sky hub will show you and the method to do so you may see on the Tips above for connecting!
