Discussion topic: What is the recommended Cat Ethernet cable for my SR203 sky router to PC?
Message posted on 26 Jan 2025 02:36 PM
I have sky Superfast Broadband "expected speed 32-50Mb", but normal download is about 34 Mpbs, upload 6 Mbps using a CAT 5 cable. Should I upgrade to a CAT 6 or CAT 8, would I get any benefit from upgrading?
Message posted on 26 Jan 2025 03:09 PM
Re: What is the recommended Cat Ethernet cable for my SR203 sky router to PC?
A category 5e will give you gigabit speeds but will give you more of your 32Mbps to that device . Category 6 and 8 would be overkill
Could you enter your full address below and post the table and notes after removing your address from the image
Message posted on 26 Jan 2025 03:10 PM
Also could you post your router stats
https://helpforum.sky.com/t5/Broadband-Talk/How-to-read-your-Sky-Hub-statistics/ba-p/3645346
Message posted on 26 Jan 2025 04:01 PM - last edited: 26 Jan 2025 04:02 PM
Cat6 is not unreasonable for domestic use, but anything higher is entirely unnecessary.
It won't improve anything unless you are currently using non-Cat rated CCA cable though.
Message posted on 26 Jan 2025 07:19 PM
Message posted on 26 Jan 2025 07:29 PM
Message posted on 26 Jan 2025 10:43 PM
Right that shows despite a top speed of 56Mbps sky has put you on a 40Mbps profile. This happens when your guarantee (handback threshold) is less than 40Mbps
Again a category 5e etthernet would suffice however a cat 6 ethernet may eek out an extra Mb or 2 if you are trying to make the most of you 39Mbps
