Discussion topic: Week Wi-Fi
This message was authored by: Stuarthunter
Week Wi-Fi
Some devices are showing low WiFi signal and one Hive system goes off line and this doos central heating
Re: Week Wi-Fi
@Stuarthunter fortunately you should be able to control your heating without the Hive system  being online. Wifi range depends on the layout and type of construction of your home so you may need additional wifi kit to get coverage in areas away from the hub. Sky will sell you their WiFi Max add-on which can supply up to 3 extenders if required see https://www.sky.com/help/articles/sky-wifi-max or you can buy and use your own equipment.
