Discussion topic: Weather station can't connect through Max Hub
Message posted on 07 Dec 2024 05:30 PM
Hi, my weather station talks wpa2 security and the new max hub only talks wpa3 - outcome seems to be that my station no longer connects to the internet. Anyone know how i can get wpa2 as default on the max hub? thanks
Message posted on 07 Dec 2024 05:40 PM - last edited: 07 Dec 2024 05:42 PM
Re: Weather station can't connect through Max Hub
To change the WiFi security level:
Open the My Sky app.
Tap Product Settings on Home or the Broadband tab.
Tap Sky Max Hub.
Tap WiFi Settings then Advanced settings.
Tap WiFi security levels.
Use the Security level drop-down and select either:
WPA2 – A lower level of security
WPA3 – A higher level of security
WPA3-T – The default level of security
Tap Save changes.
https://www.sky.com/help/articles/change-wifi-max-hub-settings
