Discussion topic: Weak wifi
This message was authored by: Fowzan
Weak wifi
Hello,
my wifi is really weak last 3 days not like before and I tried to do all the step to reset and nothing happened. Also tried to call with no help unfortunately
Re: Weak wifi
Hi @Fowzan
What exactly do you mean by weak? Is it slow or not reaching as far or dropping out?
I am NOT a Sky Employee
Avatar for Fowzan
Re: Weak wifi
Hello, It’s slow
Re: Weak wifi
@Fowzan
Could you try running a speedtest from a device your seeing issues with and report back with the speed?
Avatar for Fowzan
Re: Weak wifi
Hello,
the speedtest is:
download 14.6 Mbps and the upload 0.48 Mbps.
Re: Weak wifi
Hi @Fowzan
When you run the line test on the My Sky app what speed does it say you should be getting? Does it find any issues?
