Discussion topic: Weak wifi
Message posted on 12 Nov 2024 01:50 PM
Weak wifi
I have fitted a Ring doorbell and it says the signal is week and I get a varying delay from the bell being rand to my phone.I also only have a minimum WiFi bar on my phone while in the house.
Message posted on 12 Nov 2024 01:55 PM
Re: Weak wifi
@macca18 if you cannot move your Sky hub to improve signal level you are going to needcsomecform of booster. The hub should be out in the open on a surface above things like radiators thst can block the signal Homescwith solidcinternal walls often need multiple wifi sources. Sky will sell you an add-on called Wifi Max which can comecwith up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or you can buy your own equipment if you prefer.
