Discussion topic: Weak signal
This message was authored by: Shaun_c
Weak signal
Not being able to get a wifi connection in my living room, hub location in bedroom, my package is broadband, wifi max
Re: Weak signal
@Shaun_c You should relocate the hub if you need it in a different place, if you have it were you need it then options to deliver wireless wifi to a different and needed position would be either powerline or signal mesh pods from sky!
