Discussion topic: Weak signal
This message was authored by: Holly130
Weak signal
only getting wifi in room where the box is. The rest of the rooms have little to no wifi
Re: Weak signal
@Holly130
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
