Discussion topic: Weak security
Message posted on 04 Mar 2026 10:03 PM
Weak security
My WiFi is saying weak security I can't connect my Google hub and lights
Message posted on 05 Mar 2026 10:37 AM
Weak security
@DCJ19 all Sky hubs default to use at least WPA2-PSK which is considered secure for home and small business networks if used with a complex password. So unless you have changed the default WiFi security or are using a simple password you can ignore the warning.
Message posted on 05 Mar 2026 11:04 AM
Re: Weak security
Hi @DCJ19, as Chrisee has advised, the default security setting is at least WPA2-PSK which is considered secure for home and small business networks when used with a complex password.
If you would like to find out more about these settings, head over to our guide here https://www.sky.com/help/articles/access-your-sky-broadband-hub-settings Thanks, Becca.
