Discussion topic: Broadband not working
This message was authored by: Marzena6
Hello, I received the message saying the issue has been fixed, however my connection speed is still around 320–350 Mbps, which is well below the Guaranteed Minimum Speed of 600 Mbps in my contract. There have already been multiple engineer visits and investigations, yet the issue remains unresolved. Because of this, I would appreciate if this case could be properly reviewed by the network team, rather than repeating the same checks again. At this point I am simply asking for the service to work as agreed and for the guaranteed minimum speed to be restored. Please investigate this further and provide a clear update, as this issue has been ongoing since 27 February.
Re: Broadband not working
You are only talking to other customers here so you would need to do as your did before and contact them about this.
@Marzena6 Are you seeing that connection speed at the service checker history for your connection also? Broadband and the > expand and see what sky shows to you for the 30 day's, have a look below post 4 to give the idea if you are using a sky supplied Hub...
Service Checker bars
https://helpforum.sky.com/t5/Broadband/Broadband-speeds-reported-versus-actual/td-p/5171393
