Discussion topic: Weak security
Message posted on 25 Apr 2024 06:48 AM
Weak security
When selecting my Sky Wi-fi account on the iPhone, it says it has weak security? What is that about ? Thanks
Message posted on 25 Apr 2024 07:04 AM
Re: Weak security
@AB2 Apple, bless their little cotton socks, do love giving security warnings. What your phone is telling you is that the Sky hub is not running a new security standard called WPA3 which the latest routers run. Instead the Sky black hubs, like almost every other router that wasn't designed in the last 2 years, defaults to an older standard WPA2-PSK which most of the industry accepts is secure.so unless you have changed your hub's security settings your Wifi network is secure.
Sky do have a new white hub that does support WPA3 which comes as part of the Wifi Max package but dont upgrade to shut your phone up as its pointless as the threat of wifi hacking is incredibly remote.
