Discussion topic: Weak/non working wifi
Message posted on 11 Jul 2026 11:10 PM
Message posted on 12 Jul 2026 02:29 AM
Re: Weak/non working wifi
@Paigew994 wrote:
My body is connected to the WiFi
@Paigew994
The extremely hot weather won’t be helping but use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
