Discussion topic: Weak connection and no connection
This message was authored by: Amie101
My connection is so bad it's weak on laptop and my phone 30 steps away from the router can not connect to the wifi . It has not worked since getting the new router and the connection is terrible !
Re: Weak connection and no connection
@Amie101
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
