Discussion topic: No internet connection
This message was authored by: ST1985
Router is showing an orange light for the internet connection.  Have reset the router and light is still orange.
Re: No internet connection
@ST1985
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
