Discussion topic: Weak broadband
This message was authored by: jwilli
Weak broadband
Smart tv --- very slow couldn't do weekly call on viber to sister in new zealand 😀
This message was authored by: Me134
Re: Weak broadband
First, can you connect an ethernet cable between TV and hub? If not then unplug the hub for 10 minutes then let it reboot. If no difference try the first two links below at least.
Have a look at the following to see if they can resolve your problem easily, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
This message was authored by: SuperMatt
Re: Weak broadband
Posted by a Sky employee
Hi, @jwilli. I'll send you an invite to a private chat shortly and we can help you get this working for you.
Just look out for the colourful bubble to start the conversation. Please be aware conversations automatically close if there is no response within 48 hours. Here's more information on how Community Messaging works - https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147#M141
