Discussion topic: Poor speed between device and hub
This message was authored by: Chrisward
All our devices are slow when connected to hub acheiveing speeds of 7mb-50-90mb only.
this results in lag, streaming issues and video connectivity issues on apps
when checking external outgoing checks the modem shows 600-900mb so I can only assume this is a connection issue with modem. We are a small 3 bed terraced house
This message was authored by: Me134
Re: Poor speed between device and hub
"checking external outgoing checks the modem shows 600-900mb", I'm not sure what you're saying here but through the MySky app or online what does the diagnostic say your incoming speed is? Is it a repeatable speed? If that's fine then it sounds like just an internal wifi issue. First, unplug the hub for 10 minutes then let it reboot. If no difference try the first two links below at least.
Have a look at the following to see if they can resolve your problem easily, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
This message was authored by: SuperMatt
Posted by a Sky employee
Morning, @Chrisward. I'll send you an invite to a private chat shortly and we can help you get this working for you.
Just look out for the colourful bubble to start the conversation. Please be aware conversations automatically close if there is no response within 48 hours. Here's more information on how Community Messaging works - https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147#M141
