Discussion topic: Weak broadband signal from router
This message was authored by althorpe This message was authored by: althorpe
Just changed from Talktalk to Sky Broadband.
However the Sky signal on the router is not as strong as Talktalk.
It will not pickup the Skjy Q box in the bedroom and it is only showing 1 or 2 bars on my study desktop pc.
The location is exactly the same for both routers.
suggestions please?
Re: Weak broadband signal from router
@althorpe
Since you have Sky Q, you should report it as a Sky Q problem and then Sky will be obliged to provide you with a booster FOC.
I am NOT a Sky Employee
althorpe
Thank you for your reply and suggestion.
However Sky wants £6.50 per month on a 18 month contract.
I do not think that this is good customer service, plus it will make it more expensive than my original Talktalk account.
@althorpe
Have they said what the £6.50 is for? I assume they are trying to sell you broadband boost or something but if a Sky Q box isnt working due to a range issue this should be a free booster
althorpe
Yes it is up to two booster boxes.
The Customer Services team seem set on selling them as an additional cost.
The Talktalk router worked fine and I never experienced any  freezing problems due to poor range.
@althorpe
I'll escalate your post here so you can chat with a Sky advisor on the forum. Just note that it isnt a live chat so responses wont be instant. Look out for a message or popup in the corner of your screen.
When you talk to them make sure you talk about it being a Sky Q box issue and not a WiFi range issue.
This message was authored by Greenfingers001 This message was authored by: Greenfingers001
Posted by a Sky employee
Thanks for escalating this. We’ve sent @althorpe an invite to chat.
althorpe
I have just changed from Talktalk to Sky Broadband.
However it appears that the transmission range or signal strength on the Sky router is not as strong as Talktalk.
I am getting around 48mbs on the speed trust site which is acceptable but the Sky Q mini box picture keeps freezing and pixelated graphics appear.
I have rebooted and turned all other devices off, but the picture still breaks up
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
We are still looking to help you @althorpe . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
