Discussion topic: Weak WiFi
Message posted on 13 Jun 2026 10:25 PM
Weak WiFi
Can't connect devices such as play station consoles just says failed when we try or tablets really weak connection doesn't even reach upstairs
Message posted on 13 Jun 2026 10:30 PM
Re: Weak WiFi
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
