3
This discussion topic has been answered Discussion topic: Sky Ireland Hub configuration for Unifi router
This message was authored by: Marinero
Replacing ISP with Sky Hub and TV.  Current network is all Ubiquiti: UDM Pro, AP's and several switches.  Previous ISP box was bridged successfully.  Have tried various setting changes on Hub gui but no joy yet.
Avatar for Marinero
This message was authored by: Marinero Answer
Re: Sky Ireland Hub configuration for Unifi router
@Marinero
What connection do you have , fttc or fttp?
Avatar for Marinero
It's FTTC.
@Marinero
Do you have a modem capable of 100Mbps supervectoring such as tp link td w9970.  If not the ubiquiti is just an access point etherneted to the sky hub
If you do have a modem then you would need to enter in the ubiquiti settings
Connection type pppoe
Username              anything@skydsl
Password               anything
Vlan id                     10
