Discussion topic: Weak WiFi and mobile signal
Message posted on 12 Jun 2026 07:47 PM
I am experiencing a weak WiFi signal around the home and also a weak network signal on mine and my wife's mobile devices
Message posted on 12 Jun 2026 08:20 PM
Re: Weak WiFi and mobile signal
Hi @Stevewood1
You have posted this in the sky stream board of the community. Hopefully a moderator will movie it is to the broadband / mobile section where users with the requisite knowledge can assist you.
MikeAlanR
Message posted on 13 Jun 2026 05:43 AM
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
