05 Jan 2025 07:53 AM
Screen says no WiFi connection but everything is lit up and my phone is connected so there is WiFi. I've no idea where the WPS BUTTON is can only see a reset on the bottom of the router
05 Jan 2025 08:00 AM
Mine is doing the same and I have done this 5 times turned everything off and on and still not working. Not very good when it's so expensive
05 Jan 2025 08:12 AM
Posted by a Superuser, not a Sky employee. Find out more@Charl26 the wos button is on the right hand edge of the upright Sky hubs and can be easily missed. Put the device into WPS seacch mode then press and hold in the wps button on the hub until it starts flashing. If the device is within range they should connect within 30 seconds or so.
05 Jan 2025 11:31 AM
I've done all this myself and still not connecting
