Discussion topic: WIFI
This message was authored by: Dawn223
WIFI
No connection
Re: WIFI
@Dawn223
If it’s a broadband issue you have and you haven’t done it yet you can use this link to check to see if there are any issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
